electric fans....anyone running these, particular ones?
#74
#75
#76
Once I get this dialed in I never, ever want to watch the digital temperature again.
Sitting still I turned the dial to activate the fan at 200 degrees, and it does that reliably. But that keeps it on throughout highway driving, I assume. I guess I need to hook up the light.
The land rover temp gauge is useless. Never budges. Ridiculous.
When I stopped in the driveway with fan on it was amazing how quickly the temp dropped to 195. Like 120 seconds. The fan works, at least at stop.
Did you connect the master switch you mentioned to the yellow wire (switched power supply) or the power to the fan itself? You mentioned that it is backup for the controller so I assume it goes straight to the fan. If I put a switch on the yellow wire I could turn the fan off on the highway but that seems like alot of trouble and I will almost SURELY forget to turn it back on.
#78
#79
Ah, i guess my controller is not variable... that stinks. So your truck doesn't go above 192 on the highway? I must have some big issue. [SIGH LOUDLY]
