Electric Windows
Electric Windows
Had my driver's side window get stuck on me about 3 weeks ago. Had the mechanic determine it wasn't the fuse, but rather the modulator (or whatever it's called) inside the driver's side door. I had him wind the window up and remove that device.
For when the summer comes though, I am going to have to get that window working again. Any recommendations?
Thanks in advance for helping a simpleton Brit I am as caveman-like as they come in the clueless department. But trying to learn... ann that is the most important part I suppose!
When I get home I'll find some links for you.
Disco window regulators suck. They break constantly. Usually the problem is the failure of a little plastic roller that slides in a track. I've had to replace two where the roller broke apart. There's a company called Falconworks that makes a brass roller replacement, although it'd be expensive to do. I've always wanted to try these guys—they make other interesting high-durability parts: Window Regulator Roller, Discovery
