Electric Windows
Old Feb 13, 2016 | 05:06 PM
4x4 Brad's Avatar
Default Electric Windows
Had my driver's side window get stuck on me about 3 weeks ago. Had the mechanic determine it wasn't the fuse, but rather the modulator (or whatever it's called) inside the driver's side door. I had him wind the window up and remove that device.
For when the summer comes though, I am going to have to get that window working again. Any recommendations?
Thanks in advance for helping a simpleton Brit I am as caveman-like as they come in the clueless department. But trying to learn... ann that is the most important part I suppose!
Old Feb 13, 2016 | 05:16 PM
jamieb's Avatar
Actuators run about $45 per door on eBay. I just ordered two myself. Driver and passenger doors. Look up the videos on YouTube on window actuator replacement. Also spend the $10 to get a door panel remover tool. Those plastic clips need to be ordered and if you can save them it pays for itself.
When I get home I'll find some links for you.
Old Feb 13, 2016 | 05:29 PM
Alex_M's Avatar
Ebay is a great resource for those parts, but also try messaging Abran or Paul Grant here on the forums. I've dealt with Abran several times. Really helpful, he parts these trucks regularly.
Old Feb 13, 2016 | 10:48 PM
batard's Avatar
Disco window regulators suck. They break constantly. Usually the problem is the failure of a little plastic roller that slides in a track. I've had to replace two where the roller broke apart. There's a company called Falconworks that makes a brass roller replacement, although it'd be expensive to do. I've always wanted to try these guys—they make other interesting high-durability parts: Window Regulator Roller, Discovery
Poggi
Aug 10, 2015 12:27 AM
andrewvmurray
Oct 16, 2007 10:21 AM
silverfish
Sep 12, 2007 08:30 AM
silverfish
Jun 26, 2007 11:24 AM
BrianH
Jul 13, 2005 01:37 AM
