Electrical Issue after Head Gasket Replacement
Old Dec 30, 2017 | 10:03 PM
Charlie_V's Avatar
Originally Posted by LADisco2
So I hold down the inertial switch and lock/unlock 3 times to reset? The battery has been disconnected for 2 months but on the slow charger for 3 days prior to reinstallation yesterday.
What should I expect when starting it? What should and shouldn't I do? Do I have to bleed the fuel system before starting? Do I need to spray starter fluid in the throtte?
Thanks.
There's no reset that I'm aware of. The inertia switch stops the fuel pump and makes the hazards flash. Basically, that is what happens when you have a wreck. It can also happen of you jostle it or get towed. When I did my first head gasket job I had to press mine after a few minutes thinking I'd killed my Disco.
Number 9 is asking about the order of things, I think, to determine whether you somehow immobilized your vehicle with the sparking. Thankfully, I've never done that.
Mine was without a battery for FIVE YEARS so that should not matter.
When I disconnect the battery I make sure the ignition switch is in the on position and leave a door open. That should ensure that the alarm is not Co fused when it wakes up. Then, as others stated, I connect the positive terminal, then the negative. I haven't had a major problem doing that. If the alarm goes off when it wakes up I just put the key in the door and turn to unlock. The alarm always stops. But my horns blare when my alarm activates.
Old Dec 31, 2017 | 05:36 AM
LADisco2's Avatar
I would have drained it one more time, after dousing the rockers and lifters. Getting all of the coolant out of the block prior to disassembly is very difficult and it usually enters the cylinders/oil pan when pulling the heads. So, if you added fresh oil on top of the residue in pan...it really defeated all purposes of new oil.
For the price of six quarts of oil..I'd drain it again.
Brian.
6 qts of Rotella T5. The car sat with the drain plugs open for 2 months. Wouldn't all tbe coolant have dripped out by then?
Old Dec 31, 2017 | 07:53 AM
LADisco2's Avatar
Brian.
That would be 6 qts of Rotella T5. The rockers etc were oiled with a few shots from a vintage copper oil can--there was hardly any oil to drain. The collant drain plugs were left open for the last 2 months Wouldn't all tbe coolant have dripped out by then?
Of there was coolant in the oilpan, wouldn't that show on the dipstick?
Old Dec 31, 2017 | 09:08 AM
The Deputy's Avatar
Edit, miss read post...not sure if you are talking about oil plug or coolant drain plugs?
No, oil is heavier than oil...so it would not show up on stick. Just pull the oil plug out for a moment and drain off a small portion of what's at the bottom of the pan, maybe a quart or until it looks like nice clean oil, install plug, refill and start her up.
Brian.
Old Dec 31, 2017 | 09:56 AM
number9's Avatar
Block would be very close to coolant free as possible. About the only way to remove any residual would be by blowing out with air. Removing block drains as you apparently did prior to HG change is probably the best way to prevent coolant from entering the cylinders during head removal.
titodj
Mar 26, 2017 04:04 PM
fyanrudger
Sep 6, 2016 04:33 PM
0304Disco
Sep 24, 2013 11:14 AM
DiscoRover007
Aug 22, 2012 06:20 AM
1stevereynolds
Mar 1, 2010 06:26 PM
