Electrical mystery???????
95 Disco, when the brake is pressed and the right turn signal is on -then the turn signals stay on until the brake is released- so the orange lights stay on with the brake lights. its close to Halloween so it might be a ghost. It only happens with the right side - and yes I have checked the fuses, bulbs, contacts, wiring, switch under brake pedal- this one will need more consideration
RE: Electrical mystery???????
Seriously, check for a faulty ground connection at the rear light clusters: loose or brokenground wire, corrosion around the ground connection. Also check for corrosion inside the bulb sockets. What you are describing are classic symptoms of a bad ground...on any vehicle.
My 2nd guess would be a bad flasher relay unit. Not sure where that is located on a Disco, but usually they are located in or near the fuse box or under the dash near the steering column. Some of the veterans here would know where.
The power from your brake lights is backfeeding through the turn signals to a ground. Here is a link to help you pull the lights. Pull it and see if you still have the problem. You have to do a process of elimination to find where the problem is....
https://landroverforums.com/m_40843/..._/tm.htm#40843
