Electrical mystery???????
Old Oct 29, 2007 | 04:54 PM
97XD's Avatar
Default Electrical mystery???????
95 Disco, when the brake is pressed and the right turn signal is on -then the turn signals stay on until the brake is released- so the orange lights stay on with the brake lights. its close to Halloween so it might be a ghost. It only happens with the right side - and yes I have checked the fuses, bulbs, contacts, wiring, switch under brake pedal- this one will need more consideration
Old Oct 29, 2007 | 05:14 PM
okdiscoguy's Avatar
Default RE: Electrical mystery???????
Does the signal flash, or just have the light come on? I would pull the rear light out, unlpug the whole thing and remove it. If the front signals are still on, wiring harness, fuse box, or BECM....?
Old Oct 29, 2007 | 05:23 PM
Fonzie's Avatar
Check for a poor ground at your rear light clusters.
Old Oct 29, 2007 | 06:21 PM
97XD's Avatar
both fron and rear stay on and stop flashing when brake is applied, they stay lit up orange
Old Oct 29, 2007 | 06:23 PM
97XD's Avatar
plus another thingI noticed, whenI press the brake the trun signal indicator on the dash lights up dimmly
Old Oct 29, 2007 | 06:29 PM
okdiscoguy's Avatar
did it change anything when you removed the rear lamp assembly on that side?
Old Oct 29, 2007 | 10:38 PM
Fonzie's Avatar
Seriously, check for a faulty ground connection at the rear light clusters: loose or brokenground wire, corrosion around the ground connection. Also check for corrosion inside the bulb sockets. What you are describing are classic symptoms of a bad ground...on any vehicle.
My 2nd guess would be a bad flasher relay unit. Not sure where that is located on a Disco, but usually they are located in or near the fuse box or under the dash near the steering column. Some of the veterans here would know where.
Old Oct 30, 2007 | 10:04 AM
okdiscoguy's Avatar
The power from your brake lights is backfeeding through the turn signals to a ground. Here is a link to help you pull the lights. Pull it and see if you still have the problem. You have to do a process of elimination to find where the problem is....
https://landroverforums.com/m_40843/..._/tm.htm#40843
Old Oct 30, 2007 | 01:51 PM
97XD's Avatar
why dont I just unplug the multi-plug into that light assembly and see if it still acts up?
Old Oct 30, 2007 | 02:58 PM
okdiscoguy's Avatar
sure, if you can get to it. It was easier for me to pull the light and change all of the bulbs while I had it out......
I have a 7 seater, and even though I have long skinny fingers, I couldn't get in there well enough...
Murph2121
Nov 6, 2013 01:52 PM
Coyote
Apr 25, 2013 11:18 PM
yloDiscoII
Jul 27, 2010 11:41 PM
vandev
Jun 16, 2010 10:53 PM
meyersd
Oct 9, 2006 09:21 PM
