End All answer to stupid oil questions.
Old Jan 26, 2013 | 11:16 AM
  #131
antichrist's Avatar
You were close. WIX 51515
I don't know which MANN is being referenced, but I wouldn't use one that has a higher bypass psi valve setting (which the one in the original post has) than what is specified by Rover, which is 8.
Old Jan 26, 2013 | 11:30 AM
  #132
Thank you.
This MANN filter they speak of is the size of a iced tea pitcher and has to weigh in around 10lbs when full of oil.
I would not want that hanging off of my engine putting all of that strain on the front engine cover bouncing down a two track with no cell signal and a days walk from help.
Old Jan 26, 2013 | 11:58 AM
  #133
TOM R's Avatar
I am going with the m1-301 for this change since it is sat and available without running out to the napa store
Old Jan 26, 2013 | 12:24 PM
  #134
TOM R's Avatar
this was an interesting link
Old Jan 26, 2013 | 01:09 PM
  #135
antichrist's Avatar
Nothing wrong with them, other than being over priced.
Old Jan 26, 2013 | 05:26 PM
  #136
TOM R's Avatar
i agree but it was also on sale so... i also went with the rotella t 10w-30 see if it is better tommorow when I start up and alot cheaper then the rotella 5w-40
Old Jan 26, 2013 | 05:38 PM
  #137
antichrist's Avatar
A 10w is going to be more viscous than 5w. If it's taking a long time for the oil light to go out, you're going the wrong direction.
Old Jan 26, 2013 | 06:36 PM
  #138
amgraves's Avatar
I also purchased one of these filters in the past from WorlPac just to see how it would work. In my opinion, it is far too heavy for the timing cover. The factory replacement Mann filter is a much better choice. Besides, if you need that much filter then you engine problems anyway. LOL
Also, diesel engine oil in a gasoline engine is not a good idea either. I only use Lubro-Moly 5/40 in my 4.6 and all my customer Rover's. It stops a lot of the engine noise and isn't all that bad on the seals. Part of my job is to stop the leaks... which I have had a high success rate with. And you can run it all seasons. Just my two cents worth.
Old Jan 26, 2013 | 06:56 PM
  #139
The lower the bottom number the quicker the oil pumps through a cold engine BUT you cant actually get lower than a "5".
The higher the top number the thicker the oil is when hot.
Old Jan 26, 2013 | 06:57 PM
  #140
TOM R's Avatar
5w would be best but 10w is still lower then 15w figured I would try to find some middle ground instead of going from one extreem to the other as I am not expecting sub zeron*F temps here
