End All answer to stupid oil questions.
Old Feb 7, 2014 | 05:04 PM
  #231
dusty1's Avatar
thanks to steve's sneaky sister
Old Feb 28, 2014 | 07:00 AM
  #232
96Disco_Andy's Avatar
Okay I'm switching today to the setup in the OP. Do I need to run more than 6 quarts because of the bigger filter? I would assume that I need to run like 6.25 or 6.5, but don't want to do anything until I am absolutely sure.
Old Mar 17, 2014 | 04:42 PM
  #233
CaptainCulp's Avatar
Just use the dip stick, dip stick.
Old Oct 8, 2015 | 11:36 AM
  #234
Nitrojunkie383's Avatar
Default Oil Filter Numbers
For those who are interested... here is a list of the the oil filters we can use, both in stock size and extra capacity.
Purolator: Stock L25195 / Extra capacity L40107
Mann: Stock W930/20 / Extra capacity W950/7
Wix: Stock 51068 / Extra capacity 51773 (6.982"lg) or 51515 (5.18"lg)
Mobil 1: Stock M1-204 / Extra capacity M1-301
K&N: Stock HP-2004 / Extra capacity HP-3001
Fram: Stock PH16 / Extra capacity PH8A
NapaGold: Stock FIL1068 / Extra capacity FIL1515
I am sure there a lot of others, but maybe i got most of the ones we would normally use.
Old Feb 12, 2016 | 06:07 PM
  #235
rimasco's Avatar
Default I could only find "Heavy Duty Diesel"?
Triple Protection rotella.. What's up with that?
Old Feb 12, 2016 | 06:25 PM
  #236
dgi 07's Avatar
What's the question?
Old Feb 12, 2016 | 06:34 PM
  #237
number9's Avatar
Expand your search. TP = typical marketing BS.
Old Feb 13, 2016 | 10:20 AM
  #238
rimasco's Avatar
My bad, I should have worded better.. I can only find the rotella brand that says "heavy duty diesel".. With "diesel" oil being my concern.. My D2 is not and for some reason I can post a pic of the stuff with my phone
Old Feb 13, 2016 | 10:36 AM
  #239
number9's Avatar
Diesel oil fine in gas engines. Reverse may not be true.
Old Feb 13, 2016 | 10:43 AM
  #240
Alex_M's Avatar
Yep. All Rotella is diesel oil. The only difference is the heavier weight and the higher zddp content. The zddp content is exactly why its good for our engines because of the old school flat tappet cams.
