engaging 4wd?
Old Oct 15, 2009 | 06:04 PM
dashizzzkat's Avatar
4th Gear
Default engaging 4wd?
i just recently purchased a 1995 discovery and need help with engaging 4wd.
can someone explain the procedure on how to put into 4wd high and low and is there 2wd or is it kept in 4wd high for everday driving?
I messed around with it a little today and managed to get into 4wd low but it seemed to take quite a bit of effort. is this normal?
Old Oct 15, 2009 | 06:26 PM
oysterhead's Avatar
you're always in 4wd (normally in hi).
to shift into low, be sure to either (1) roll slowly while in neutral or (2) push on the gas a bit while sitting still in neutral.
if it hasn't been engaged in a long time, you might need to lube the linkage.
Old Oct 15, 2009 | 07:25 PM
LR's are full time four wheel drive, NOT part time 4x4, NOT all wheel drive, but FULL TIME FOUR WHEEL DRIVE.
Back and to the right is normal, that is 4 hi, forward and to the right is 4 lo.
Back and to the left is 4 hi locked, meaning that both driveshafts are locked together so they get equal amount of power, snow and off road use only.
Forward and to the left is 4 lo locked, same as hi locked only with lo gear.
Here are a few things for you to read to help you get better educated on your new purchase.
https://landroverforums.com/forum/sh...ad.php?t=21328
Old Oct 16, 2009 | 09:05 AM
antichrist's Avatar
If you don't have the owners manual, which explains it all, download the rave manual from green-oval.com, it has the owners manual.
philo73
Dec 17, 2007 02:00 PM
vimal
Freelander
Dec 11, 2007 04:24 AM
Tanrover
Nov 26, 2006 04:09 PM
db1047
Apr 27, 2006 08:10 PM
