Engine died whilst driving. Won’t turn over.
Old Aug 28, 2022 | 05:38 PM
Extinct's Avatar
Put aluminum foil on the cover and you will never have another problem
Old Aug 28, 2022 | 08:44 PM
Karmakannon's Avatar
Originally Posted by mln01
There is no difference. Both "turning over" and "cranking" mean the same thing.
And yet many people use turning over to describe a no start, but engine is still cranking situation. Makes no sense to me.
Old Aug 28, 2022 | 10:10 PM
mln01's Avatar
That's why we try to educate here.
Old Aug 29, 2022 | 04:42 AM
Avinashj's Avatar
Angry
Originally Posted by BlackShama
Hi, currently sitting behind a safety barrier on a 60mph road waiting for AA.
Disco 2 V8 2004 60k miles.
Turned engine off whilst parked about 30 mins back, wouldn’t turn over when trying to start it back up. UG was showing voltage dipping from 12v down to 11v when trying to start, someone helped jump start and we left it running for 15 mins seemed fine and UG was showing 13v and healthy everything. No codes.
Driving home, after 20 mins on a 60mph hill the engine just cut out. Ultraguage first showed a symptom of engine temp ERR after the engine died, then screen went blank and obviously power steering and brakes went out.
Coasted to a safe location and pulled handbrake at 2-3 mph to stop the car.
Windows, lights, radio works but car tries and fails to start.
Crank pos sensor maybe? Alternator issue?
Extremely unnerving to be doing 60 down a steep Scottish hill towards a roundabout and everything to fail haha. Luckily no traffic today because everyone is away for the holiday!
-----------similar case happened to me . There was noise at rear and car stopped . windows lights on , also starts and stops .. frustrating .
Old Aug 29, 2022 | 01:12 PM
ahab's Avatar
Think of it this way. The crankshaft is turning over, which means the pistons are moving up and down, but the truck won't fire. The starter makes the engine turnover, combustion makes it run. Not turning over is what happens when your battery is completely flat.
Old Aug 29, 2022 | 01:58 PM
mln01's Avatar
Or when the starter isn't working.
Old Aug 29, 2022 | 03:24 PM
BlackShama's Avatar
I was thinking about something like this - assumed the heat from the exhaust (that me and AA guy both burnt our hands on ) eventually kills the sensor like heat does to all electrical components. Must be some sort of heat shielding or insulation fix to extend the life a bit.
Appreciate the education on 'turning over' as well. Help me correctly diagnose in the future.
Out if interest, any reason jump cables connected to another battery worked to start the engine? Or was it just coincidence that by the time we hooked up the cables everything had cooled just enough?
Old Aug 29, 2022 | 04:57 PM
mln01's Avatar
Coinkydink (coincidence)
Old Sep 2, 2022 | 11:57 AM
BlackShama's Avatar
Job done. Hopefully genuine Bosch sensor and the shiny gold stuff keep things running a bit longer.
Old Sep 2, 2022 | 12:08 PM
dtmbinb's Avatar
Nice work.
Neal@lorientconsulting.com
Dec 27, 2021 10:25 PM
Caleb.hunter
Aug 31, 2015 06:11 PM
twmj1953
Jan 30, 2013 11:07 AM
armyeng
Mar 8, 2011 05:58 PM
caleb
Jan 25, 2010 06:26 AM
