Engine mounts
So i was at the hobby shop changing out a rack and pinion on my friends G35 and i remember i had brand new engine mount in the back of the rover. So after i was done i proceeded to change em out, i knew they were bad but i didn't know how bad they were until i jacked up the engine.
![](https://lh3.googleusercontent.com/LnkjpQ4mc9HBciWtziaTy5qY7GKwiNkOSGJ9kPRcCjt6XMSeRTm8rB2H1k1Oz_eOmr8ZsHs6cVy7zxUwG4GT3PmbuKJ1_RfWcymz-YAQ0AOJ0Xo0-FYTXb84hGe9tSBlg16UejiTXhlahe7FNIdbBql8-JvOkeDYEcYXGv2WI1z6xymVwq8xn1ULTRNx06KcTG5kZiJnKWcp-Voz0W1c7CRduhVU9yryT8YO7gf4LnL4i4AJE5IssrVrq1-_aDpDVeqOfBsa2-4mR98MMFbE3XBomELADHZ2pG-vPgAta_3rRIIKE71367HiGKTGk632H4bWgi-MyWALu073jXfpp5QPF4V_Cs3rpNMBlzgQlZeMiSVWwgZoxr5VnGlz3xoj6Ooj2SRVa25Sq6KhLWc0FNzV6kigCyguMyNzHmGqSQrXlT4k_eMGFmgfAHrhC4la0Hzo05ZFv1d9hb_rWlrT5u2LFo2pT_KNIozoh3mlIw0GLCB9icOEHIen9pHRS8HE154QNitEim8PgR0R9GepyhBgfVMm2V8Ge7pgnFDklesHglWtLq4y_-ljp8g9sLzIWg9KjvFHAujmqHgwwpoYhxQRl84IhWpdmrIamNiCw55VF0nNgQ=w1299-h975-no)
![](https://lh3.googleusercontent.com/gzcypCa7A0PL9vnOpDGtU3cppsKVlMLsnY21co0ilFMpM_G5oxrEKttHDwABXul5C5moMrkhRugbp03fBITj-MQicSiBYUcjueL8aZ9jnIcZuS5DhVlEVl2IbCfPml1ZluT2xCNpPZBBYdqLxu4Oe0a_AS5uK-sCOra4dViROR_tjcNvQ7EW89TSk1tki8Nr5OFJMIe85NFzPwlFG17sMIbGBoXzOva_QzGuISL3hJ6HX7RDZkEnERtl2HTkiXewF2Haf5FpTH5tgnw8ov_AZxuP1ItBUFpb-4hOK0l6kNqJIPs0YHFw_UIS0qQMIxdyOY48IhlfSy1ib1trDWu4I-wJo7VUbWjLuqIJEU4NjxBk5bgeAXKntpVG49iwW82PTIV5XId9D05YqN-KjmVUo9yKRnvFV8PIh8X4nV2TYqsXBCDiS_LAXQdaEj0cN4W34lCKHF82SJ3Qc-dn3s71c6PoN8qOlM1YuexZOpVdGuSSTxbGFFvhmycBBmCtwLHhcWkRE7QYKzE3aCt4SG7_5QWFAKhQ8X0misqTmLuC01EnKOWNBR7KQqei9Lyiwc-iPHfSktrDgw3JtV2U2RC_Q1KjIlpCa4Kc4AOCPYowiLOl7vxdnw=w1299-h975-no)
I just used a regular floor jack and jacked the engine up via the oil pan. One thing to note is that you need a torque socket to get the studs out of the bottom of the mount. It makes it alot easier to remove mount once the top nut is undone. Another thing that you will need is a realy short 18" ratcheting wrench, it made the driver side top bolt alot easier to get out.
The rover does feel a bit smoother when accelerating and i no longer hear my exhaust rattling against the frame. As for the torque stud, mine came off easy on the passenger side but was a pain on the driver side. All i had was a wrench so since both my mount basically sheared i just jacked up the engine enough to pop it out.
badfysh
Member Group And Special Buys
01-21-2015 11:33 PM
chup1
09-04-2012 08:48 AM
