Engine mounts
Old Sep 25, 2016 | 09:42 PM
Daedrix's Avatar
Banned
Default Engine mounts
So i was at the hobby shop changing out a rack and pinion on my friends G35 and i remember i had brand new engine mount in the back of the rover. So after i was done i proceeded to change em out, i knew they were bad but i didn't know how bad they were until i jacked up the engine.
Old Sep 26, 2016 | 06:02 AM
batard's Avatar
I wouldn't have seen those as suspect from the outside. That's interesting. How did you jack up the engine? With a regular jack and a block of wood on the oil pan? Seems it might be worth inspecting.
Old Sep 26, 2016 | 07:56 AM
Daedrix's Avatar
Banned
I just used a regular floor jack and jacked the engine up via the oil pan. One thing to note is that you need a torque socket to get the studs out of the bottom of the mount. It makes it alot easier to remove mount once the top nut is undone. Another thing that you will need is a realy short 18" ratcheting wrench, it made the driver side top bolt alot easier to get out.
Old Sep 26, 2016 | 08:45 AM
Andy2Rover's Avatar
Any noticeable difference it how the truck feels after changing the mounts? Smoother and quieter?
coors's Avatar
Did you have any trouble removing the torque bolts? Out of the two times I changed mounts they always have me trouble. I ended up sawing through the mount and removed the carnage in multiple pieces.
Old Sep 26, 2016 | 01:40 PM
Daedrix's Avatar
Banned
The rover does feel a bit smoother when accelerating and i no longer hear my exhaust rattling against the frame. As for the torque stud, mine came off easy on the passenger side but was a pain on the driver side. All i had was a wrench so since both my mount basically sheared i just jacked up the engine enough to pop it out.
badfysh
Member Group And Special Buys
Jan 21, 2015 11:33 PM
chup1
Sep 4, 2012 08:48 AM
EricTyrrell
Nov 21, 2011 12:18 AM
lipadj46
Aug 19, 2010 10:32 PM
btbaus
Nov 16, 2009 01:40 PM
