Engine Noise
Old Apr 23, 2021 | 11:59 AM
redrover75's Avatar
It does appear that it starts right around 170 degrees. Going to run water over it later to see if I can manipulate it, but seems like this may be a fix.
Old Apr 23, 2021 | 12:07 PM
dswilly's Avatar
My engine was notably noisier like that when at 200f before the Extinct thermo-wonder conversion. All noises were at idle and went away immediately on throttle tip in. That noise sounds familiar pre-thermostat change. Now I have a intermittent "lighter" tapping at idle which I think is a lifter. Comes and goes and fades to nothing once throttle is applied. My engine is tired at 175k but runs fine.
Old Apr 27, 2021 | 11:06 AM
redrover75's Avatar
Water does seem to cool it off and stop the tick. Which i suppose is good news. Chris, the person doing the work, mentioned that acetone and ATF mixed is great for loosening rust, so I have been spraying it daily, hopefully make it go more smoothly. I do wish I had the space to do the work myself, seems fairly straightforward, thanks to your PDF write up.
Old Apr 27, 2021 | 03:08 PM
Extinct's Avatar
You can drop down to a 170 degree thermostat, it will throw a cold engine code if it is a 03-04 but usually only in the winter, summer it heats up so fast it won't throw the code. You could drop down to a 160 but then even the 99-02s will throw a code. BTW, if the code bothers you , you can throw in an 99-02 ECU or flash yours with the early engine program.
Old Apr 27, 2021 | 04:05 PM
matt3502's Avatar
How do you reset an ECU?
Old Apr 27, 2021 | 07:27 PM
Extinct's Avatar
LR Test book, I forget the other hardware/software combo that, can do it. My guy in Greenville SC was able to flash a used ECU from an 03 to a 00, don't remember the name of the hardware.
Rustic
Jan 19, 2010 10:59 PM
shelleyman
Jun 26, 2008 10:18 PM
base
Apr 13, 2008 04:48 PM
russ00001
Feb 2, 2008 09:07 PM
Eulogio
Jan 21, 2008 04:17 PM
