Engine quit in drivethru line - related to codes 0440 0455?
Old Feb 13, 2018 | 09:08 PM
knhughes34's Avatar
5th Gear
Question Engine quit in drivethru line - related to codes 0440 0455?
I know that my 2001 disco is nearing the end of its commission - it has over 200,000 miles and I definitely have an oil leak that's more expensive to fix than what the car is worth, BUT I've been able to keep it filled by checking it about once a month. I've had a P0455 code for little bit.
Today I was idling (not in park) in a drivethru line and my car just stopped. There wasn't any indication this was going to happen. I tried to start it again, and it would crank, but not turn over. Had a restaurant employee help push me to the side.
About 30 minutes later, before calling AAA, I tried it again and it started. Ran rough, but not that bad. I got home fine. When I read the codes, it gave me P0440 and P0455. Would either of those issues cause the car to just stop? When it stopped, there was no misfire (that I could detect, at least).
I checked the oil, too, and was definitely low.
I suppose that the engine dying could be unrelated to the codes, but it seems like if something like that happened, you'd get a code for it.
Any thoughts would be GREATLY appreciated!!!
Old Feb 13, 2018 | 09:29 PM
DiscoCam's Avatar
Those codes are for evap leaks, seems unrelated to the problem. Symptoms sound like a failing crank position sensor. I might be wrong, so let's wait for some more replies before taking action.
Old Feb 13, 2018 | 11:43 PM
LR03NJ's Avatar
As DiscoCam suggestion. CkPS. Thats the usual symptoms. 200k is not the end yet. I have see 300k and still strong. Low oil can cause permature failure.
Old Feb 14, 2018 | 01:52 AM
shanechevelle's Avatar
You need to check more than once a month.
Once a week is a better piece of mind.
Old Feb 14, 2018 | 01:59 AM
mln01's Avatar
Yep, classic, textbook crankshaft position sensor failure story.
Old Feb 14, 2018 | 01:18 PM
Best4x4's Avatar
Sounds like a CKPS to me as well.
Old Feb 14, 2018 | 01:29 PM
Motorhead1's Avatar
The next time the vehicle doesn't start, use live data on your code reader and see if the R.P.M's are registering on your devise when you are trying to start the rover. If no, then the CPS is bad.
bshea992
Jun 7, 2012 01:41 PM
wild driver
Jun 7, 2012 09:25 AM
bosshogt
Dec 23, 2011 10:24 AM
kingsly
Dec 27, 2009 12:25 PM
ryanD2
Jun 25, 2009 06:00 PM
