Engine Swap advice
Old Oct 26, 2012 | 07:58 AM
ttwndoc's Avatar
Thanks for the info. I live here in oklahoma. No emissions or vehicle inspection. So other than operation problems I may be in good shape. Hopefully the donor is SAI. Motor was given to me. 20,000 miles on the motor. Are the heads as hard to change as a diesel heads are?
Old Oct 26, 2012 | 08:01 AM
drowssap's Avatar
no they come off rather easily, especially because you will be doing it with the motor out of the car. Pull off the intake and exhaust manifolds, valve covers and your 16 bolts way from new gaskets.
Old Oct 26, 2012 | 05:17 PM
ttwndoc's Avatar
Hey drowssap you have convinced me to swap the heads and do it right. Thanks for the advice. I have the rover on the lift and donor motor on the stand still with transmission attached. This looks like it is going to be a very interesting project. We are going to dive in in the am.
Old Oct 26, 2012 | 10:29 PM
JavaRacer's Avatar
Don't forget to take pics and post 'em here!
Old Oct 27, 2012 | 10:00 AM
ttwndoc's Avatar
Okay just a thought anybody taken the body off the rover to do an engine swap? That is how we do the diesels
Old Oct 27, 2012 | 11:00 PM
ttwndoc's Avatar
Well we took off the body to do the swap. We are changing the engine and the transmission. thought 30,000 mile on both versus 130,000 miles on my old. Might as well do both.
Old Oct 28, 2012 | 12:09 PM
JimmyTomahawk's Avatar
why flush the dexcool and go with 50/50? are there issues w/ dexcool and what are the benefits of 50/50? or, is your comment specific to his situation w/ the engine swap? I've been wondering about this. thanks!
Old Oct 28, 2012 | 01:04 PM
wreckdiver1321's Avatar
Dexcool does not cool the engine as well as normal yellow or green coolant and leaves a gunky residue inside the cooling system that lessens the system's ability to cool. Traditional yellow or green 50/50 doesn't do this and flushing the cooling system and replacing the coolant with 50/50 will actually drop the engine temps quite a bit.
Old Oct 28, 2012 | 08:50 PM
ttwndoc's Avatar
Hey Guys I have the body off waiting on new engine mounts. The mounts were all busted. Had question upon the engine swap someone asked if there is a security code or some code that I have to have to swap motors. I kept the orginal computer module. But I have the other one as well. What do I need to do or what is the problem with this and the engine swap? Experience is needed on this thanks for any advice.
Old Jan 8, 2013 | 06:04 PM
Rodsram's Avatar
Any update or pictures on this, as I am ready to pull the trigger on doing the same.
Thanks in adv'.
Rod
austinlandroverbill
Jun 23, 2014 02:01 PM
bennyb43
Dec 11, 2013 08:17 AM
nateandnikki
Jul 2, 2013 06:38 AM
ttwndoc
Nov 15, 2012 11:50 AM
Justin
Feb 11, 2005 01:55 AM
