Engine Swap Question
Can anyone tell me if the 4.0L engine in a Disco 1 is the same as the 4.0L in a 97 Range Rover? I'm looking at a Range Rover on ebay with a bad engine and I'm thinking about bidding on it if there's no significant difference between the two. I can understand if the exhaust manifold and engine mounts might have to be swapped.
Eric
Eric
I would double check on the front cover....It would suck to have to swap after swapping the engine. I was wrong about it being bosch, that is what changes the timing set, but I would still check the cover.
David Kadasia
Mar 22, 2010 09:56 AM
