Engine Swap Question
Old Jan 17, 2010 | 04:56 PM
SDinDS's Avatar
Default Engine Swap Question
Can anyone tell me if the 4.0L engine in a Disco 1 is the same as the 4.0L in a 97 Range Rover? I'm looking at a Range Rover on ebay with a bad engine and I'm thinking about bidding on it if there's no significant difference between the two. I can understand if the exhaust manifold and engine mounts might have to be swapped.
Eric
Old Jan 18, 2010 | 09:12 AM
oljohnboy's Avatar
I would think so, I would call a dealership and ask them to confirm.
Old Jan 18, 2010 | 11:43 AM
okdiscoguy's Avatar
No. The Rangie has a Bosch engine like a D2. Block and heads are the same, but you will have to swap the front cover, timing set and knock sensors.
Old Jan 18, 2010 | 01:19 PM
SDinDS's Avatar
I was just at the dealer picking up some parts and asked the guy in the service department about it and he said it's a direct swap. I don't have to change anything. Tempting.....
Eric
Old Jan 18, 2010 | 01:34 PM
okdiscoguy's Avatar
I would double check on the front cover....It would suck to have to swap after swapping the engine. I was wrong about it being bosch, that is what changes the timing set, but I would still check the cover.
Old Jan 18, 2010 | 04:48 PM
Just look at the manifold to see if the Rangie engine is a Bosch or not, that is the biggest deciding factor.
Old Jan 19, 2010 | 09:52 AM
okdiscoguy's Avatar
Mike, is the front cover the same on a RR gems 4.0 and a Disco 4.0?
bennyb43
Dec 11, 2013 08:17 AM
David Kadasia
Mar 22, 2010 09:56 AM
morriswh
Sep 2, 2007 10:03 AM
xb70valkarye
Sep 22, 2006 10:45 AM
Justin
Feb 11, 2005 01:55 AM
