Engine won't fire - stranded with multiple codes
Old May 12, 2016 | 02:11 AM
jfall's Avatar
You can analyze the codes with
http://enginecodemaster.com
I typed the codes from the RAVE into that for LandRovers.
Old May 12, 2016 | 02:12 AM
jfall's Avatar
Yeah. Replace the crank sensor.
That is classic engine gets hot and quits.
Doubt if it is the fuel pump.
And as drowsap says, if you try to start it at hot and no RPMs then smoking gun for crank sensor.
A bit hard to replace as fitting it seems to be a bear.
Old May 12, 2016 | 05:58 PM
borchera's Avatar
Be mindful of the spacers - they fit one way.
nosup4u
Jun 16, 2014 02:54 PM
Chapman Conti
Aug 28, 2013 06:36 PM
pwaltrip
Nov 28, 2012 09:27 AM
boldingm
Mar 15, 2010 05:59 AM
