Entire tail light housing not working
Old Sep 12, 2022 | 08:22 PM
robertrankin's Avatar
7th Gear
Default Entire tail light housing not working
I have an 02. One of the two top tail light bulbs were out so I removed the housing to replace them. Attempted to replace them with LED bulbs. After swapping bulbs, when I tested it none of the lights worked. I checked the fuse (I believe 11) and it was fine. I also thing the tag light is on that fuse and currently working.
The connection looks fine and, as far as I can see, the wiring isn’t corroded. Before I go buy a new tail light (I’m assuming the board is bad?), are there any other ideas? I’m not insanely mechanically inclined, but like to think I could change a bulb
Thanks.
Old Sep 12, 2022 | 09:09 PM
Harvlr's Avatar
This advice might be completely out to lunch but if it was me, I’d try removing the LED’s and installing the correct bulbs and see where I was at.
Old Sep 12, 2022 | 09:14 PM
7th Gear
Sorry forgot to mention, when the assembly didn’t work with the LED bulbs I removed them and put the old bulbs back in and still didn’t work. My thought is the LED possibly blew the board? Just figured I’d ask if that makes sense before I buy a new tail light
Old Sep 12, 2022 | 09:50 PM
mln01's Avatar
Do you have a multimeter to check the circuits?
Diagnose, diagnose, diagnose; don't just throw parts at a problem.
Old Sep 13, 2022 | 11:15 AM
Harvlr's Avatar
Are you sure the old bulbs are ok?
Old Sep 13, 2022 | 04:55 PM
7th Gear
To follow up, I’m a moron and it was the bulbs. A bulb that was previously working went out in the process somehow. If anyones curious the tail light bulbs are 12v5w
Thanks all
Old Sep 13, 2022 | 07:13 PM
Harvlr's Avatar
Good to hear. Thanks for keeping us informed.
Motorhead1
Dec 16, 2014 09:40 AM
JimmyTomahawk
Nov 20, 2014 12:18 PM
gott-wagons
Dec 26, 2010 07:15 PM
fluffdaddy
Mar 29, 2008 06:24 PM
fitch11
Oct 24, 2007 09:04 PM
