Exhaust Question
Old Nov 2, 2017 | 07:26 AM
zuke's Avatar
Default Exhaust Question
I need to change out the donut gaskets between the exhaust manifolds and pipe. Cant seem to find them anywhere. Any ideas?
Old Nov 2, 2017 | 07:41 AM
LR03NJ's Avatar
Is this the one youre looking for? Plenty on ebay.
Old Nov 2, 2017 | 07:46 AM
OverRover's Avatar
ETC4524, but as mentioned get the "kit" the studs break real easy.
> https://www.ebay.com/itm/BEST-Rover-...JYDUFw&vxp=mtr
Old Nov 2, 2017 | 11:03 AM
Best4x4's Avatar
I absolutely hate messing with those things!! I’ve used anti-seize, bolts, Ford Studs, and they’ll still break on ya. Makes a 10min job turn into a mess!
Old Nov 2, 2017 | 11:42 AM
OverRover's Avatar
OMG that's so true! Those studs fall into the category of "Not IF they will break, but WHEN they will". It seems for every 1 time I get lucky and can remove all 6 nuts, I get kicked in the A$$ on the next truck I do. Lets hope zuke has better luck.
Old Nov 2, 2017 | 01:22 PM
Sixpack577's Avatar
About to unbolt mine.
Kinda what I figured.
Yay.
Old Nov 2, 2017 | 04:49 PM
Best4x4's Avatar
My 05 Jeep Wrangler constantly broke the exhaust studs, so I modified em by drilling them out to 5/16 bolts and used anti-seize and lock washers. I wish I could modify the LR D2 the same, but the only way I found to get it fixed 100% is pull the entire manifold, place it in a vise and soak it drill, or twist the broken studs out which you can’t do while it’s mounted on the D2 due to space limits.
twaszak
Jul 15, 2012 07:21 PM
Pwn777
Jan 13, 2012 08:49 PM
Street Wolf
Jun 24, 2011 01:59 AM
theworks001
Nov 11, 2008 03:04 AM
sailorcolin
Apr 24, 2008 08:38 PM
