Faking out the sai
Old Feb 5, 2020 | 03:21 PM
Sixpack577's Avatar
Originally Posted by Best4x4
Yep “some” 03-04’s are non SAI! I’d just get a non SAI ECU & go from there. I’m not 100% certain, but I’ve also heard that a system like the Autologic can make changes to the ECU & if SAI is an option it could be turned off. Just haven’t had a big chance to piddle with the 10k Autologic system to know for sure what it can/can’t do.
A year or 2 ago I read here about a UK company that could flash a D2 ecu, for around $500.
It was a few small changes, mainly adding more timing at lower rpm's for a little more get up and go.
I have heard nothing about them since.
I wonder if something like Ecu Unleashed works on D2s?
And if it or the UK flash could turn off SAI?
Then 4 pipe thread plugs for the heads and pitch the rest.
Old Feb 5, 2020 | 03:45 PM
mollusc's Avatar
And all of this assumes that you don't have to go for any emissions testing. Trucks with SAI show up as Low Emissions Vehicles in the testing system here in New York when the machine reads the VIN. If your VIN says the truck is an LEV and the ECU doesn't report that the system is present and error-free, you're not going to pass.
Old Feb 5, 2020 | 04:27 PM
zuke's Avatar
Well I got something rigged up on a temporary basis to see if it works. I have started it and ran 2 times since then with no CEL popping on but time will tell.
Old Feb 5, 2020 | 04:44 PM
Sixpack577's Avatar
Are the SAI pipes still on the engine?
Blocked off?
Old Feb 5, 2020 | 05:33 PM
XRAD's Avatar
nanocom has several programming options for SAI 'ON/OFF' . I have non SAI ecu and all options are off. Not sure if you could turn SAI options to 'OFF' on an ECU w/SAI using nanocom.....
Old Feb 5, 2020 | 09:07 PM
Extinct's Avatar
You just need to flash the ECU with a non-sai program. My guy in Greenville would do it for $75. As far as tricking it, yes the ECU looks at the oxygen sensors, does not look at the load on the pump.
Old Feb 5, 2020 | 09:37 PM
Sixpack577's Avatar
What else can he change in the ecu?
Timing??
Old Feb 6, 2020 | 06:12 AM
Extinct's Avatar
Eurover is the name of the shop, Greenville SC. He has a Testbook, so he can flash factory stuff only. Reasonable price, tons of trucks, so I would bet he could do a mail in service and get it flashed for a bit more - you know, install ecu in one of his other trucks for the connection.
Old Feb 6, 2020 | 07:09 AM
JUKE179r's Avatar
Can't electronically turn off SAI with a Nanocom.
Under the Motronic ECU Inputs it only shows the SAI pump, SAI system, & SAI solenoid valve are on/off or active/inactive as you mentioned.
Old Feb 6, 2020 | 07:44 AM
XRAD's Avatar
Thanks for clearing that up JUKE!
2Guinness
Oct 3, 2018 05:52 PM
Llamasayswhat
Aug 12, 2018 09:36 AM
zuke
Apr 23, 2018 09:33 PM
DeepBlueWater
Nov 7, 2007 05:33 PM
ajh
Nov 5, 2007 02:12 PM
