Falconworks shuttle valve kit
Old Jan 13, 2011 | 10:02 AM
agthird's Avatar
Default Falconworks shuttle valve kit
anyone buy this kit and have success with the three amigos?
http://www.jewellamberoil.com/sales/...v1ucis12qmqu93
Old Jan 13, 2011 | 01:30 PM
tbesselman's Avatar
Sure did - I was getting the 114 electrical error - and the amigos, and this quickly fixed it, just follow Josh's intructions for the ground and installation, and wa laaaa no more amigos
Old Jan 13, 2011 | 03:06 PM
agthird's Avatar
are you saying you bought the kit and did one of josh's fix...
Old Jan 13, 2011 | 06:17 PM
dcarr1971's Avatar
Isn't this pretty much just a new shuttle valve? If so, I think L8 has one on their eBay store for $73...
http://cgi.ebay.com/ws/eBayISAPI.dll...m=290516575276
Old Jan 13, 2011 | 08:08 PM
Nope. it was redesigned years ago for the Hummer's which use the same system and at Falcon Works, you can also buy new seals that are not offered anywhere else from what I have found.
Old Jan 14, 2011 | 08:52 AM
dcarr1971's Avatar
Thanks for the clarification Mike. That's good to know. If I pull the shuttle valve and find that it's leaking I'll just order the Falcon Works replacement then...
Old Jan 14, 2011 | 07:26 PM
bosshogt's Avatar
A question? If you pull ABS modulator apart. How can you tell if its leaking or just needs the joint sodered doing Josh's fix? Will there be brake fluid past certain place and thats the sign you need the seals and the part from Falcon Works?.
Old Jan 15, 2011 | 12:28 PM
agthird's Avatar
if you look at the write up for the abs fix josh talks about where the fluid gets past the seal there's acouple of pics as well...
bosshogt
Feb 2, 2012 06:52 PM
sayeedA
Dec 20, 2011 05:00 PM
aarongregor
Nov 14, 2011 08:31 PM
majrmike
Oct 9, 2007 03:13 PM
rovernbama
May 9, 2006 11:12 PM
