Fault codes P1514, P1551, P1884
Old Jan 11, 2013 | 04:49 AM
Kobloking's Avatar
Default Fault codes P1514, P1551, P1884
I recently changed my wires (to Magnacore 8mm), spark plugs (to Bosch platinum plus 4s), oil, filter (to K&N), and MAF. However, I'm now having the bone mentioned fault codes (P1514, 1551, and 1884) and rough idling. Anyone knows wht could be causing this?
Old Jan 11, 2013 | 08:11 AM
Concentrate on the 1514 and 1551 codes. They relate to wiring or connector issues with the IACV. Tech sheet from ECU manual attached. The 1884 code is most likely the result of this, the tranny computer and engine computer are always whispering to each other about engine load, etc.
File Type: pdf
Old Jan 12, 2013 | 12:27 PM
Kobloking's Avatar
Savannah Buzz thanks a bunch. I will keep you posted on my progress
Kobloking
Jan 20, 2013 07:39 AM
peanuts8888
Dec 1, 2010 10:14 AM
tailchaser0527
Jan 18, 2010 07:53 AM
