Feels like front wheel drive
Old Jun 29, 2011 | 11:57 AM
cbwhitley's Avatar
Default Feels like front wheel drive
My 04 disco feels like only the front wheels are pulling. The front tires also look to be wearing more than the back. I remember that there was a way to disable the rear shaft and only pull from front if there were issues with the rear shaft. Where doni check to see if the rear is disengaged?
Old Jun 29, 2011 | 12:47 PM
hilltoppersx's Avatar
incorrect.
pull the front shaft. engage the cdl and try and drive.
Old Jun 29, 2011 | 03:50 PM
kenk's Avatar
For the rear to be disengaged, you would have to remove the rear drive shaft. Look underneath and look for a round shaft going from the center of the truck back to the rear axle.
Old Jun 29, 2011 | 04:00 PM
You have no knowledge about your Disco and the drive train.
How often do you rotate tires, what air pressure are you running front and rear and if you slowly turn a full turn circle in a parking lot, do you hear the front tires chirping?
sDot
Sep 11, 2014 08:39 PM
Benjamin Wright
Feb 23, 2013 10:22 PM
dansgt
Feb 13, 2011 06:40 PM
bikingteacher
Nov 19, 2010 06:31 PM
Aquaholic
Jun 15, 2007 10:30 AM
