A Few Problems
I just bought a 2003 Discovery HSE7. It runs great, but there are a few issues.
First, the three amigos and the brake light are on. Is there are cause that would make all 4 come on? I have read about the three amigos and the brake light separately, but I am not sure if they all 4 are on.
Second, the driver's seat doesn't adjust as I think it should. It raises up, the back goes up and down, but the seat doesn't go down in the back or the front part of the seat doesn't move. Also, the heater in the driver's seat doesn't come on. Anyone know what could be the cause?
Third, it is equipped with a DVD system that has headrest monitors. The DVD player is under the back seats. The remote is not available, but we tried to put a DVD in. IT shows, but the picture is jumping and is black and white. Could it be bad wires, bad player, or a dirty player?
There are a couple other issues, but I know what the problem is there. The worst is the brake lights that are on. Over all, I am pretty happy with the truck.
2nd, Seems that your problem is electrical contacts. Check fuses and connections. Broken switch could also result to not function. HEating elements in the seat usually get cut inside and wont work. Heating elements need to be replaced.
3rd, remove dvd, connect leads to an external TV and see if B&W still. If same, replace DVD, laser could be bad or it could be just loose connection but i doubt.
