Finally getting around to installing an oil pressure and temp gauge
Old Feb 15, 2010 | 09:28 PM
lipadj46's Avatar
Default Finally getting around to installing an oil pressure and temp gauge
I'm finally getting aroung to installing an oil pressure and oil temperature gauge in my DII. I bought this oil filter adapter as it offers 3 ports:
http://www.glowshiftdirect.com/oilfi...-34unf-16.aspx
I went with electric digital gauges:
http://www.glowshiftdirect.com/blue-...ure-gauge.aspx
And a dual pod:
http://www.glowshiftdirect.com/Unive...-Dash-Pod.aspx
Not sure exactly where I am going to mount it yet. I will take some pics and post here once I get around to installing it. I still have to get a couple add a circuit fuse thing-a-ma-bobs to power the gauges and sending units.
Old Feb 15, 2010 | 09:38 PM
greg409's Avatar
Cool, I last week mounted the same adapter - love it.
I used an APC oil press ga. & volts, water temp.
Mounted a three ga pod in recess on top of dash (DI), wife hates it, which is good.
luck,greg
Old Feb 15, 2010 | 10:20 PM
Willie00d2's Avatar
Can you still use the long filter with this adapter? I like to use the K&N 3001 filter.
Willie
Old Feb 16, 2010 | 12:28 AM
EstorilM's Avatar
What's the easiest way to get a coolant temp reading?
I might add all of this to my spring to-do lists when I replace and upgrade a lot of the cooling components.
Old Feb 16, 2010 | 08:38 AM
AK Rover's Avatar
Pretty cool. I have found in the past that digital gauges can be distracting while driving. I prefer to just glance over and see a needle rather than trying to actually read a number while driving.
lipadj46's Avatar
I do believe that I will still be able to use the longer filters, we will see.
As far as the easiest way to moniter the coolant temp, just buy a scangauge II.
I went back and forth between analog and digital and decided to go digital but I can see both sides.
Old Feb 16, 2010 | 05:18 PM
antichrist's Avatar
With an analog, if you get one calibrated so the needle is in the middle at normal pressure, you don't even need to look at it, which is a good thing when driving. After you have it for a while you can "sense" the needle position just from your peripheral vision. That lets you focus on driving, not reading and processing numbers.
Also, with a digital gauge a change from 52 to 48 (or vice versa) will draw your attention to the gauge, even though it doesn't matter. An analog needle would move very little with that change and not draw your attention from the road, or trail.
Old Feb 16, 2010 | 05:20 PM
antichrist's Avatar
Land Rover had it right in the Series Rovers.
DustyLBottoms
Aug 6, 2015 08:39 PM
DustyLBottoms
Aug 6, 2015 01:49 PM
bballjames
Jul 13, 2012 03:34 PM
Kingmarine
Feb 26, 2012 09:27 PM
lipadj46
Oct 17, 2010 06:34 PM
