Fire extinguisher mounting suggestions
Old Nov 25, 2015 | 02:39 PM
batard's Avatar
Default Fire extinguisher mounting suggestions
I have a small car fire extinguisher I can mount somewhere in the car. Any suggestions on best places for it?
Old Nov 25, 2015 | 04:33 PM
Alex_M's Avatar
I'd put one in the center under the rear seats in a solid mount, or perhaps on the back of the center console either vertically or horizontally under the bottom.
Old Nov 25, 2015 | 04:44 PM
Best4x4's Avatar
Back Door is a good spot (unless you can't open it from the outside!!!) I have two marine fire extinguishers mounted back there along with a Mag Lite, and 2 molle bags.
Old Nov 25, 2015 | 06:38 PM
mln01's Avatar
If you want to have one in your truck I'd think you'd want to be able to reach it from the driver's seat. I like Alex_M's idea of mounting it on the rear of the center console - mostly out of the way but still accessible.
Old Nov 25, 2015 | 06:47 PM
toofaroffroad's Avatar
Mine is mounted on driver seat right at my feet.
Old Nov 25, 2015 | 10:07 PM
Colorado David's Avatar
Can you post a picture? Thanks.
Old Nov 27, 2015 | 02:14 PM
batard's Avatar
Thanks to all for the suggestions. I've played around with it, and I'm going to either have to mount it to the rear door, put it under one of the front seats or in the passenger's wheel well. It won't quite fit on the back of the center console. I'm leaning toward putting it as close as possible to the driver's seat for fastest access.
Old Nov 27, 2015 | 09:03 PM
Best4x4's Avatar
I had one mounted near the drivers seat in my 05 Rubicon, and after a very hard stop it flew out of the crappy plastic fire extinguisher mount and got wedged under the pedals.
I had to secure it and after that it was no longer just a quick grab. I could run around to the rear door just as fast if not faster and grab one.
Old Nov 28, 2015 | 09:57 AM
Racer X's Avatar
This is a very bad idea...
And this is exactly why.
I have mine mounted to the rear door, the mount is screwed into the plastic surround above the rear door subwoofer.
That said, I do have my life hammer mounted on the seat bottom panel at my feet.
Old Nov 28, 2015 | 11:50 AM
Sorry for the late reply. Here is a photo of mine mounted under the driver seat. I would not use the crappy clamp it comes with. This has been secured for a couple years. It works great.
I had mine on the back door for a while. It was fine except when I was camping. When the truck is loaded to the brim, the extinguisher always seemed to be in the way.
Cohbra11
Member Group And Special Buys
34
Nov 4, 2013 03:19 AM
03discoman
May 9, 2010 11:56 PM
DiscoRom
Dec 13, 2008 08:31 PM
Landzu
Jan 15, 2008 07:01 AM
