Fixed exhaust leak and now throwing engine codes. Advice needed.
Hey guys, I wanted to get some advice before throwing parts at my current problem. I have 3 codes: P0150, P1174, and P0159.
Some history. I had an exhaust leak on the drivers side where the downpipe meets the exhaust. According to a hand and smell test, this is now gone. From my understanding the codes I have now are indicating the opposite side of the engine. I reset my codes and after 2 days the cel came back on due to the codes above. The exhaust smells rich to me and the amount of white smoke while cold seems a little excessive, it is also idling rough warm and cold.
The truck is a 2004 with 94K miles. I have had it for a year now and had to change the crankshaft sensor about 2 months ago, i also had a code at one point that indicated evap leak and a new gas cap fixed it. I expect to be told to change all 4 02 sensors due to reading some other post but I wanted to make sure my code combo wasn't pointing at something else. I have an old SnapOn scan tool if reading O2 voltage will help diagnose in any way.
Thanks for the help!
Throwing Engine codes?
Beats throwing a Rod.
Try
http://enginecodemaster.com
Codes and explanations from the RAVE book.
Try
Snafu / Disco Fries
08-20-2013 09:05 AM
