flashing check engine light
Old Aug 2, 2005 | 09:23 PM
JRdisco1's Avatar
Default flashing check engine light
flashing check engine light means NO driving right? I did have to drive it home from work I was thinkin maybe I should jeep it tomorrow. It will stay constantly lit for a few minutes after cranking(maybe 5 miles) then starts flashing. Bad news for sure....
Old Aug 3, 2005 | 03:24 PM
mikemeyer0's Avatar
Default RE: flashing check engine light
Steady on, get it fixed as soon as you can
Flashing, Park it do not drive, it only flashes if something wrong is bad that will lead to major problems, also sometims it is emmisions.
I would not drive it until i got it scaned, before you take it to dealer try renting a auto zone scanner and give it a try, if it is not a test book problem it will read it, (maybe what year?0
Old Aug 3, 2005 | 04:05 PM
JRdisco1's Avatar
I already had the good fortune of getting an obd II scanner from atlantic british. The codes I'm bgetting say:
No 1 cylinder misfire,
Misfire that could damage catalyst? excessive emissions
and an ever present faulty o2 sensor
Old Aug 4, 2005 | 12:40 AM
duboff's Avatar
the do not go, is the right way until you know what is up with the vehicle. sorry but getting it checked is a must. to continue could mean alot more problems. duboff.
Old Aug 4, 2005 | 01:14 AM
Bait's Avatar
Fix your misfire codes first. PO301, check the Ig wire to #1 plug. If it is all corroded, replace plug and wire.
Old Aug 4, 2005 | 11:45 PM
JRdisco1's Avatar
I replaced all wires and plugs today. I also installed a B&B cold air intake, looks good. I used my scanner to erase the codes. I drove it around for a while and it hasn't thrown a code yet. It may just need more time to go through its "cycle" . It's runnin' very smooth now and the borla exhaust with the intake has really kicked it up a shot!
Old Aug 5, 2005 | 03:43 AM
Bene's Avatar
you found an intake for it? what year?
cobbcj7
Oct 16, 2014 07:48 AM
FlyingZebra34
Feb 22, 2014 05:39 PM
Buzzwalburg
Oct 23, 2013 04:52 PM
Gilbert
Jun 8, 2009 11:33 AM
tvsmark
Oct 1, 2008 08:09 PM
