Flashing D
Old Mar 28, 2021 | 06:59 AM
Tony C.'s Avatar
5th Gear
Default Flashing D
Any idea why D flashes on dash and on gear shift indicator?
Old Mar 28, 2021 | 08:24 AM
TyTyBinks's Avatar
It put the truck into limp mode. I found this information on another post:
Sounds like it's going into 'limp home mode' i.e 3rd gear only and no gearbox changes. Does the M&S lights come up simultaneously? It could be a few issues, the battery charge is too low, the xyz switch is defective or needs adjusting or just a gearbox ECU glitch.
Old Mar 28, 2021 | 08:47 AM
Tony C.'s Avatar
5th Gear
Thanks! M&S lights do come on simultaneously. I'll test the battery first. Xyz switch sounds a lot more involved!
Old Mar 28, 2021 | 08:54 AM
TyTyBinks's Avatar
It happened to me once after the truck had sat for a while. It ended up being the battery wasn’t connected all the way.
Old Mar 29, 2021 | 05:53 AM
Tony C.'s Avatar
5th Gear
Thanks. I adjusted the battery cable and it is working now. Flingers crossed.
Chrisinhouston
Jul 1, 2020 04:39 AM
Ivan0z
Apr 18, 2020 12:32 AM
DiscoDrew9
Jan 7, 2018 08:52 PM
DiscoBuckeye
Jul 28, 2016 09:42 PM
texmanmoore
Apr 22, 2015 03:08 PM
