Flashing "engine service soon" help
Old Oct 14, 2011 | 09:58 AM
frankieoboy's Avatar
Originally Posted by hilltoppersx
flashing means turn the damn thing off until it's fixed.
Read the manual !!!
Old Oct 14, 2011 | 06:21 PM
G Reeves's Avatar
thank you, I can and do follow directions. The flashing and the miss fire has stopped and i was only taking SWMBO to the air port and not all the way down. The disco is laid up and I will be into the auto shops in the morning to get a scanner. I may be British but i am not stupid and was only asking if any body had had a similar problem as I use to fix defenders and heavier green equipment not use to 4.6 V8's as they are to expensive to run in the UK
Old Oct 14, 2011 | 09:57 PM
Mr. G,
The jump from an older Defender to a D2 involves a lot of electronics. Suggest you download the RAVE set of shop manuals. Link below. Also, here is a link to a 4 meg publication about the codes for D2, with more tech info. http://jimsrover.afraid.org/rover/di...BD2%20info.pdf
Old Oct 15, 2011 | 10:42 AM
hilltoppersx's Avatar
Originally Posted by frankieoboy
Read the manual !!!
i am the manual
Old Oct 15, 2011 | 08:44 PM
Mr. G.,
Please understand that all levels of expertise are welcome here, and we frequently have new posters who have worked up the nerve to ask a question, but not the nerve to check the oil level on the dipstick. People are trying to keep someone from making a damaging mistake, it is a level of concern that is a positive action, but may be a little gruff to get attention.
Having worked on Defenders, you would be more at home on a D1, but the D2 will be easy to master with the documentation.
You'll also find this to be a lively bunch, full of questions and suggestions, and a few OM's thrown into the mix (Obnoxious Maximus).
Old Oct 16, 2011 | 07:56 AM
dparham's Avatar
If you have a code reader or scanner, great. If not, the bigger auto parts stores will read the codes for free. Pretty good deal, since some shops charge $89 to plug in a scanner. With that info you can work on what the issue is and not throw parts at it. Some of the sensors that could be involved are more than $300.
Just a side note That I found out about auto zones here at least in south florida, they are not allowed to CLEAR codes, so for me, Ill be getting one... I like that KIWI wifi to use with my iPhone... Any experience with this one? its about $150
coupled with that O'Car radio ( Oxygen Audio ) one could have everything at fingertips right on radio dash! hmmm...
Old Oct 16, 2011 | 09:31 PM
I got a plain jane one that I can move from car to car, but I must admit the advanced widgets are interesting. But I also subscribe to the conspiracy theory that dealerships download new trouble codes to pop up when you pass within wifi range. Don't want my Disco to start reading this forum, something else will leak...
richief556
Feb 3, 2021 04:55 PM
Take THAT, Jeep!
Sep 4, 2013 06:44 PM
G Reeves
Oct 17, 2011 11:38 AM
jareblake
Nov 23, 2010 06:07 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
