Flat Battery and no door key.
Old Jul 8, 2019 | 09:31 AM
CptPhil B Prosser KT's Avatar
Default Flat Battery and no door key.
have a 1999 disco 2 with a replacement door lock. the key is inside...doh... and the battery is flat. can anyone help please. have tried trickle charge thru the starter motor positive, tried to open bonnet, its more secure than fort knox.. have the key fob but also have flat battery double doh.
Old Jul 8, 2019 | 10:23 AM
Richard Gallant's Avatar
Locksmith to pop the door, that is about your only option. You could do a search for broken hood cable it is possible to open the hood from the outside
Old Jul 8, 2019 | 12:27 PM
Ben Matheson's Avatar
Jumper cables from spare battery or jumper3box to starter motor and frame/ ground. Takes just minutes
Old Jul 9, 2019 | 09:06 AM
GregHman's Avatar
Default I used the trailer light cord
When I had that same problem I applied power through the trailer light cord and then the fob worked
Old Jul 10, 2019 | 05:36 AM
thanks everyone, tried the power under car method, run the porta pack flat, gfot a locksmith out, job done in 2 mins .
1953andrejrigoli
Nov 30, 2018 08:04 AM
victoria1309
Apr 25, 2013 08:46 AM
amalfi88
Mar 28, 2011 07:58 PM
zqwester
Feb 8, 2009 07:02 PM
