Foam strip for ventilation air intake
Old Feb 16, 2012 | 08:47 AM
jafir's Avatar
Originally Posted by bearcatfans
Not expensive at all. Just order this one and install.
Exactly.
Old Feb 16, 2012 | 10:38 AM
creepin's Avatar
Originally Posted by jafir
Replace it soon. It will get sucked into your blower motor.
10/4 I'll order now...Thats a cheap part to.....(for a rover)
Old Feb 16, 2012 | 11:07 AM
twaszak's Avatar
I found my new pollen filter at a specialty store that sells foams for furniture and anything/everything else foam can be used for. Bulk item on a roll, cut to order, and sold by the foot/yard, with a 10 inch or so minimum, rather than pre-packaged panel/sheet.
It was very similar to the original material and/or the filter material Spike555 mentioned in his post.
Like Spike555's solution/post it was really cheap, and came in a sheet* that had to be cut to size etc.
I wouldn't be surprised if the only differences were that Spike555's was pre-packaged and came from HomeDepot.
So if the Foam store is closer than HomeDepot, (or if HomeDepot has run out for some reason) maybe check there first. Oh, and while you're at HomeDepot, you could check the water pump / water feature section in the land scaping department. The same or similar material is used filtering water.
Same probably goes for any tropical fish / aquarium stores.
Cheers,
Thomas
Old Feb 16, 2012 | 12:26 PM
creepin's Avatar
I think the easiest thing to do is call Atlantic British.....$11.95 its in your hand in two days.....
Filter Pollen (Genuine Part # JZL100120) - Land Rover pcv & pollen/cabin filters from Atlantic British
Old Feb 16, 2012 | 03:34 PM
I had an old filter, but also a fan full of tiny leaves blown up under the hood I guess. When I did the new filter (Spike method), I cut an extra piece and shoved into the fresh air intake that leads directly down to the heater fan. Some one posted a photo of a fan full of hood blanket shredded insulation, others have had pine straw, etc.
Old Feb 16, 2012 | 05:49 PM
Colin Haycock's Avatar
Default filter gauze/mesh
Originally Posted by rimasco
is that intake for the cabin?? I need to replace as well
I used it for the air intake on the bulk head at the back the engine compartment, the one that runs the entire width beneath the windscreen wipers...stops the leaves and dust etc getting into the airstream.
RANDY04D2
Mar 3, 2025 04:29 PM
DiscoBritney
Dec 27, 2011 09:45 PM
paulfromperu
Apr 19, 2009 10:14 PM
Luv2Disco
Nov 16, 2008 10:46 PM
targotsi
Sep 23, 2008 08:02 AM
