Forgot how much pia rover work is
Old Jun 6, 2021 | 10:34 PM
redwhitekat's Avatar
Default Forgot how much pia rover work is
Reminded myself how much harder it is and pia to work without a lift compared to a car
went under to check fluids etc found plugs for oil cooler ports lose wow imagine if they fell off lol 2 of the 3 nuts for exhaust studs gone
some insulation off wires everything is just hard up reach Looking at the cps sensor connector etc thinking how am I gonna reach that lol coated the inside of the frame with eaton stuff sprayer
what’s that mod you guys do to the cps sensor cover ??
Old Jun 7, 2021 | 03:25 AM
The Deputy's Avatar
Yeah, since you can only get one hand up in there, to release CPS sensor plug. Made this out of an old brake tool, originally made for removing drum brake springs. Removed rivet and use the hooked end to grasp upper CPS plug, slip it around wires and it holds the upper part of the plug while you reach up with one hand to remove lower portion of plug (attached to CPS sensor). Snapped a pair of visegrips on the end of tool and reached in through opening between frame and inner wheel well to grasp upper plug, worked like a charm.
Removing CPS sensor isn't that difficult if you use 1/4 drive ratchet, swivel and extension, you can come in from between exhaust manifold and head for the inner nut. Naturally, the rover is on jack-stands, for added mobility under vehicle.
Heck, if the exhaust studs are broken on CPS sensor side, remove manifold and you'll have easy access to sensor.
Old Jun 7, 2021 | 07:40 AM
wjsj69's Avatar
I cut the inner fenderwell with a grinder and bent the sheet metal out of the way for full access. Bent it back when done. Tape it, weld it, glass it if you want. I've had no issues with two cuts in the metal.
Old Jun 7, 2021 | 05:33 PM
I got up there today to wrap the cover. Pain in the *** but oh well
thanks for the tips
TimInNova
May 12, 2020 07:06 AM
Flyin4AWA
Jan 19, 2020 05:20 PM
discosven
Jun 8, 2015 05:32 PM
aarons02
Apr 27, 2013 06:41 PM
ViennaDisco
Sep 25, 2010 04:16 PM
