Fox shocks from LK8
Old Jul 22, 2023 | 08:26 PM
whowa004's Avatar
lol L8 strikes again. Sorry to go through this but honestly not surprised.
Old Jul 30, 2023 | 07:44 PM
AoSaludaNC's Avatar
3rd Gear
I received an updated bracket from Lucky 8 this past week. It was closer to size but not close enough to match the factory holes in the spring perch. I didn't want to bother drilling larger holes given how thin the bracket was so just removed the bracket and used the eyelet mount. Not exactly what I would call "direct bolt...requires no modifications at all".
Originally Posted by FtWDisco2
I talked to LK8 and they are waiting on Fox to get them "another" bracket for the lower front mount - they told me to hang on to mine and they would send me either a new bracket (not sure I really want to change it out myself since I just bought them) or make a plan once they got a new batch that worked.
He did say they sent an actual correct mount to Fox as an example this time - not sure why this was such a new idea...
But honestly - I am leaning toward just returning them and getting Bilstein 7100s if Simon or anyone else has the ones tuned for the D2 - not worth all this BS to save $500 at this point.
Old Jul 30, 2023 | 07:50 PM
FtWDisco2's Avatar
so did you use the RTE adapter to use the eyelet mount?
Old Jul 30, 2023 | 07:52 PM
AoSaludaNC's Avatar
3rd Gear
Yes I did
Old Jul 31, 2023 | 03:30 PM
SundayFunday's Avatar
I’ve ordered a few sets of fox for my D2 via Rovers North - and even despite Fox opening a new manufacturing plant towards the east coast I hadn’t had any issues with front mounting plates..
I would be calling fox directly to find out what the issue was.
Old Jul 31, 2023 | 03:46 PM
FtWDisco2's Avatar
so you are saying you have received and installed without modification front 2.0 shocks on a D2 without needing the RTE or some other adapter ?
Old Aug 1, 2023 | 06:20 AM
That is what I’m saying
Old Aug 7, 2023 | 10:26 AM
Betteron2wheels's Avatar
Lucky 8 sells these knowing they don't fit. Thier response when I contacted them was to go thru Fox for warranty issue. Called fox and tried to find a bar pin that would work; I sent pics and dimensions, great customer service and tech support but we couldn't find a bar with correct spacing. I ended up getting RTE cross pin eliminators. Even with that they were a pain to install, I would hate to have to remove them outside of a shop environment (like on the trail)... If I were going to do it again, I would get Bilsteins for ease of installation.
Old Aug 7, 2023 | 10:37 AM
FtWDisco2's Avatar
which Bilsteins would you get? the 7100 or would you go for the more traditional 4600 kit ?
I am about to send my Fox 2.0 back to LK8 due to literally no follow up since they told me they were trying again to fix it...
Old Aug 7, 2023 | 01:37 PM
I would probably go with the 4600. Cheaper and I don't plan on desert racing or hardcore rock crawling..
Sara Anctil
Apr 30, 2017 09:37 PM
Anson Cone
Feb 22, 2017 11:00 AM
Discolife
Jan 27, 2013 11:16 PM
willrok13
Jun 15, 2011 01:07 PM
discocolorado03
May 30, 2006 03:49 AM
