Foxwell NT530 Vin
Old May 30, 2020 | 12:08 AM
  #21
Richard Gallant's Avatar
My 520 works fine, actually had to use it today to test the ABS pump, exactly the same process as @JUKE179r
Old May 30, 2020 | 02:06 AM
  #22
JUKE179r's Avatar
I always wondered if the NT-530 model was only geared towards newer vehicles though the Disco 2 is on there.
I’ve seen corrosion inside the SLABS unit on the circuit board and on the connector pins. You can easily open up the SLABS unit by removing 2 allen/hex head screws and look for corrosion or a broken/burnt trace or components.
Old Jun 5, 2020 | 11:41 AM
  #23
mojocoggo's Avatar
Just wanted to update this thread as I went through the same thing with my NT530. I was about to return it and just order an NT510 or NT520.
I sent a message to Foxwell and they actually updated the Land Rover software and provided me with a new working .bin file to replace the old one on the SD card for the scanner. The original file to replace is located in Vehicles > Europe > LandRover or something like that. BTW, Foxwell has like 6 different ways to contact them, the one that worked for me was sales@foxwelltool.com.
It still won't automatically read the VIN (not a big deal), but the "VIN error" buttons are now fixed and the ABS bleeding should work now.
I've attached the file for anyone who needs it. Hope this helps!
File Type: zip
Old Aug 4, 2020 | 09:00 PM
  #24
tuita's Avatar
7th Gear
Originally Posted by JUKE179r
You shouldn't have to input your VIN.
Once you plug in the Foxwell (this is on my NT510), turn the ignition key the II position then follow these steps to get to #3 ABS in the 6th screen below...
Thanks brother,I have foxwell nt510 elite
Old Aug 20, 2020 | 09:50 AM
  #25
dparham's Avatar
same here.. I ended up returning it and getting the NANOCOM 4. then got notice of update lol oh well I'm still super happy with NANOCOM. I did email them but they never responded for weeks so that's why I returned but then BAM UPDATE! I don't fault them or put any negative on the product just timing was off and in these times that's not unexpected.. if it had worked Id kept it at the time and I even considered holding on to it as it really did some nice things just I needed the break bleeding to work and it to read SLABS properly... I'm assuming now it does
abran
May 14, 2020 12:18 AM
cornbreadj
Jun 1, 2015 08:26 PM
Richard Moss
Sep 5, 2014 03:09 PM
DiscoRom
Jan 27, 2009 05:03 PM
ScottJ
Oct 2, 2007 02:19 PM
