Frame Cross Member for Oil Sump Removal
Thanks
This may be my stupidest post yet... but I thought the body was mounted to the frame. I assume you mean jack the frame and not the axel.
Torched my bolt heads off to get the crossmember out. Can't believe Rover used such soft 8mm bolts to attach the crossmember to the frame - how stupid. They should have used at least grade 5, probably grade 8. I plan to grind down the slag, drill out the remains of the bolt threads and use 3/8" grade 8 bolts to reattach with nuts up top. Just another Disco hassle to add to the list.
cogsley
08-13-2014 03:24 PM
