Frame Cross Member for Oil Sump Removal
Old Jun 18, 2014 | 08:30 AM
abran's Avatar
Harbor freight sells a set of metric sockets for extracting stripped bolts, works very well. I would try that before drilling out the bolts.
Old Jun 18, 2014 | 08:54 AM
powderhound's Avatar
Originally Posted by drowssap
unbolt the pan, jack the body up and you will have room to take the pan down, with the member in place. at least i did
That's the answer I was looking for. I was afraid of dropping the pan, not being able to get it out, and having a royal mess on my hands.
Thanks
Old Jun 18, 2014 | 08:55 AM
RoverMasterTech's Avatar
Hammer a 3/8 6 point socket on them and break them off. Then use self tapping I-beam screws to screw it back up in a slightly different position. (been there 100 times.)
Old Jun 18, 2014 | 09:18 AM
groeder24's Avatar
I just removed mine because my driveshaft was touching it and have had no problems that I would know of. But I am thinking about adding some spacers to it and putting it back.
Old Jun 18, 2014 | 10:02 AM
drowssap's Avatar
Just be sure to jack the body and not the frame, i believe i tilted it to the passenger side so i could remove it without taking the pickup off, if you want to remove the pickup i would think it would come out easier
Old Jun 18, 2014 | 10:55 AM
This may be my stupidest post yet... but I thought the body was mounted to the frame. I assume you mean jack the frame and not the axel.
Old Jun 18, 2014 | 11:12 AM
drowssap's Avatar
correct, my misspoke
Old Apr 11, 2015 | 11:40 PM
Fast951's Avatar
Torched my bolt heads off to get the crossmember out. Can't believe Rover used such soft 8mm bolts to attach the crossmember to the frame - how stupid. They should have used at least grade 5, probably grade 8. I plan to grind down the slag, drill out the remains of the bolt threads and use 3/8" grade 8 bolts to reattach with nuts up top. Just another Disco hassle to add to the list.
tito5590805
Apr 28, 2020 12:53 AM
zski128
Jan 12, 2015 03:01 PM
cogsley
Aug 13, 2014 03:24 PM
knightmetro
Jun 10, 2014 02:49 PM
mike111
Jun 2, 2014 08:58 AM
