Front crank seal install
Old Jul 6, 2022 | 09:30 PM
Edge77's Avatar
Default Front crank seal install
Folks,
Last summer I changed rod bearings, oil pump, water pump, bla bla bla.
I also replaced the front crank seal with a genuine LR seal, which was leaking right after the repair.
I did not use the official LR install tool for the seal installation, LR-12-089.
I am going back into the truck soon to replace crank main bearings and want to fix the leaking front crank seal.
1. Should I buy the official tool for $100 (uuugghhh)
2. Can I make a tool?
Any advice appreciated, just want to get it right the 2nd time.
thanks in advance!
Ed
Old Jul 6, 2022 | 10:32 PM
WildPackofFamilyDogs's Avatar
So I have the tool and I found uses for it other than specifically the front seal.
I finally used it on the front seal and it was nice to grab, press the seal in, and not think twice about the fitment. Peace of mind versus using a makeshift socket or flat bushing press kit. Bushing press kit or sockets I believe would totally be feasible, and the tool is probably not needed at all. But don’t trust me as I am a laymen still for these vehicles.
Hope that helps.
Old Jul 7, 2022 | 07:39 AM
Sandman614's Avatar
Originally Posted by Edge77
Folks,
thanks in advance!
Ed
Pretty easy to make the crank pulley tool, I drilled 2 sets of holes to use it on my Tacoma too. Check the crank for wear, you might need to get a speedi-sleev
Old Jul 7, 2022 | 01:46 PM
Extinct's Avatar
I don't use a tool, just put some silicone on the od and tap it in with a hammer around the perimeter.
Old Jul 7, 2022 | 04:58 PM
Discorama's Avatar
I had the same issue and I found out that the shaft was worn. Put on a sleeve or get a new pulley. I did not use any special tools. PVC fitting from the hardware store for $2.39 or something like that to push the seal in and air impact wrench to get the nut off. Tightened by blocking the flywheel.
Amazon Amazon
https://www.roverparts.com/engine/pu...ts/lhg000060g/
Old Jul 8, 2022 | 12:15 AM
JohnZo's Avatar
My mechanic just pushes seals in with his thumbs. He has a great feel for it after thousands of vehicle repairs.
Westminster02
Mar 15, 2022 01:39 PM
woldisco
Mar 9, 2021 08:10 PM
Willie 00D2
Nov 6, 2017 03:16 AM
0304Disco
Oct 17, 2012 04:11 PM
outdoor7or24
May 21, 2012 08:34 AM
