Front Crank Shaft Seal
Old Apr 18, 2016 | 11:06 AM
cammyr01's Avatar
Thumbs down Front Crank Shaft Seal
Good morning! Any suggestions on which brand/part# is best to use when replacing the front crank shaft seal? I see several that will work, thought I'd check with you guys before I purchase.
Thanks in advance for your help!
P.S. Is there anything else I should look at when replacing? Is there anything else I need when replacing the seal? :-) Thanks guys! This single mom appreciates you all!
Old Apr 18, 2016 | 11:15 AM
OverRover's Avatar
Part #: ERR6490G and get a CORTECO. I never have an issues with any of their seals.
Trevor at Rovahfarm has them>>> Middle of the page... RovahFarm for all your new Land Rover Parts and Accessories
Old Apr 18, 2016 | 11:27 AM
cammyr01's Avatar
Thanks, that's the one I was about to order, and thought I better ask you guys first!
Have a great day!
Old Apr 18, 2016 | 04:14 PM
Alex_M's Avatar
If you've got to pull the front cover then definitely timing chain and oil pump. I can't recall if you've got to pull it or not.
outdoor7or24
May 21, 2012 08:34 AM
gplandrover
May 20, 2011 02:48 PM
yloDiscoII
Feb 10, 2010 10:03 PM
djmik2000
Jan 28, 2009 03:58 PM
modelwerks
Oct 3, 2005 09:29 PM
