Front Driveshaft Out...CDL only moves to center position
Old Oct 23, 2019 | 01:08 AM
stereophile33's Avatar
Default Front Driveshaft Out...CDL only moves to center position
Moves freely to the first click, but refuses to go to the second click to lock.
Any ideas?
Old Oct 23, 2019 | 01:34 AM
acg's Avatar
acg
What is your model year?
Old Oct 23, 2019 | 01:53 AM
gears are not meshed (I don't think) as they make a gear on gear gsshshs sound when I move from drive to park
Old Oct 23, 2019 | 02:14 AM
actually just got it all the way over....but its not locking....still seems like gear mesh is off.
Old Oct 23, 2019 | 02:54 AM
acg's Avatar
acg
You may not have CDL on your 2000 model year. Have you checked to see if you actually have the CDL engage/disengage nipple on the top of the transfer case? This is circled in the pic below.
Old Oct 23, 2019 | 02:56 AM
Has the nipple
Old Oct 23, 2019 | 11:00 AM
At this point it doesn’t matter which of the three positions it is in neither driveshaft flange will rotate and when putting the tranny in park it makes a grinding sound.
inhad this happen years ago when shifting from high to low range and the transfer case gear mesh got off.i don’t remember what I did to fix.
Old Oct 23, 2019 | 03:20 PM
Sandman614's Avatar
That's a clear indication the T-case is in neutral. Turn one of the flanges by hand (engine off) while you turn the selector. If it won't go into high or low, that could mean the selector fork inside is trashed.
Old Oct 24, 2019 | 12:00 AM
after several hours experimenting I have opened up a new thread that more accurately describes what I am working through
https://landroverforums.com/forum/di...90/#post706754
PDX Disco II
Jun 8, 2016 07:32 PM
Zelatore
Dec 7, 2015 10:58 AM
TRIARII
Apr 11, 2013 05:25 AM
RedAustinIX
Mar 21, 2012 08:35 AM
cptshanman
Dec 14, 2007 10:16 PM
