Front Driveshaft Question
Old Apr 28, 2019 | 11:05 AM
cvhyatt's Avatar
Default Front Driveshaft Question
I have heard that the OEM front driveshaft does not have a grease fitting which can cause it to fail. I checked mine this morning and found that it had a grease fitting. Does this mean it has already been replaced?
Old Apr 28, 2019 | 11:27 AM
lordmorpheus's Avatar
No. If that is the only grease fitting in the shaft, it has not been replaced. The original shaft had a fitting at the front joint, but the 2 rear joints were sealed. Replacement shafts have fittings at the rear joints also.
Old Apr 28, 2019 | 11:34 AM
cvhyatt's Avatar
Got it! Thanks!
Old Apr 28, 2019 | 01:25 PM
Discorama's Avatar
Don't grease it, replace it! After I bought my used D2, I greased it where I could and then it failed and took the transfer case output shaft bearing with it. It looks like the greasing made the shaft turning unevenly and causing vibration. After 200 Miles Hwy transfer case it was shot. Repair was very costly since the shop wanted a new TC in and their labor is not cheap here.
Jared Kay
Mar 4, 2023 05:08 PM
ahab
Jul 7, 2018 03:28 PM
cimomd
Sep 23, 2017 04:54 PM
asulil
Jun 13, 2013 09:55 PM
