Front HUB Assembly and brake issues
Old May 28, 2010 | 09:14 PM
  #21
jycsalas's Avatar
in case you need it
http://www.landroverclubvi.com/front-hub.html
Old May 28, 2010 | 09:23 PM
  #22
lipadj46's Avatar
Also http://www.discovery2.co.uk/fronthub.html
Old May 30, 2010 | 08:43 PM
  #23
bookerbr's Avatar
Ok, I just changed the calipers and pads. The left rotor was damaged from the heat of the bad caliper, so I got a new left rotor. I did notice any play with the hub assembly, so I am assuming it is still in good condition. I will keep my eye on it.
I took the car for a ride to "seat" the brakes in and notice a little smoke when I returned and parked the car. I might have had a little residue on the new rotor. Is this normal?
Old May 31, 2010 | 01:04 AM
  #24
If you did not clean the new rotor with brake cleaner then yes, the oil that they coat them with to keep them from rusting will burn off.
Quinten
Mar 10, 2014 10:24 AM
croller63
Jan 7, 2012 08:55 PM
Chrisinhouston
Nov 9, 2009 01:37 PM
jennii
Oct 11, 2009 08:16 AM
Avgrognet
Nov 30, 2005 02:40 PM
