Front-Left ABS Connector Fix
Old Mar 26, 2026 | 04:49 PM
mln01's Avatar
Try one other free remedy next.
A few years ago, I was chasing a LF bad sensor code. Years before that, I had the corresponding code for the RR sensor, and learned then that sensor codes are very often not due to bad sensors, but to bad connectors. I spliced the RR wires and all has been well since then. Lesson learned.
I tried the same thing with the LF connector after I checked continuity and resistance. The splice did not correct the fault. No bueno.
After scratching my head for a while, I thought the next remedy was going to be installing a new sensor with the looong wires intended to be run directly from the hub to the SLABS. But those wires come with bare ends.
After looking unsuccessfully in many places online for an illustration of the individual terminals (pins) for the SLABS "Molex" connectors, I decided to dig in and unplug a SLABS Molex to take a look. That didn't really help, so I reinstalled the Molex and put everything back together.
Then, lo and behold, there was no longer a fault and the code has not returned for what I think is now five years or so!
I have since read other examples where simply unplugging and reinstalling a plugged-in connector cures an electrical fault. Doing that is said to lightly "scrape" the metal surfaces, restoring connection. I call that removing "microcorrosion".
The first time doing something like this worked for me was -50 years ago.
All of a sudden, no power was getting to the starter on my '65 Mustang. The battery had a full charge, and was relatively new.
I checked every connection between the battery and the starter and all were good. All I did was remove the ring terminal from the high-amp post on the starter, scrape the surfaces a little with a screwdriver, and reconnect them. Did the trick.
Old Apr 15, 2026 | 07:22 PM
dparham's Avatar
hmmmm yeah maube I just hard solder them in and call it a day lol
Old Apr 24, 2026 | 09:31 AM
cappedup's Avatar
I was going to post this as a new thread, but this seems like a better place.
I have been chasing a FR sensor fault for a couple of years! I tried everything apart from the hard splice.
Until I read somewhere that not all contact cleaners are equal. I’ve always been a “De-oxit” guy, but learned that it specifically leaves a little residue as a protector.
I tried CRC QD.
CRC 05103 QD Electronic Cleaner...
Amazon Amazon
This apparently doesn’t leave a residue, and after cleaning the same connector I’ve cleaned before my issue has been absent for about 4 months now.
Old Apr 24, 2026 | 11:12 AM
mln01's Avatar
Great! Sometimes the solution is the one most simple. Just which connector did you clean?
Old Apr 25, 2026 | 07:53 AM
cappedup's Avatar
Both the FR bullet type connecter, plus the block at the slabs unit.
So I couldn't tell you which was the fault.
DakotaTravler
Jun 28, 2024 08:05 PM
LR-CAN
Nov 23, 2020 09:39 PM
Geo
Apr 9, 2018 01:17 PM
Externet
Dec 12, 2015 04:44 PM
forsakenriceboy
Mar 13, 2014 11:37 AM
