Front Passenger side window regulator/ horn beep
Old May 25, 2011 | 02:41 PM
Gerard's Avatar
Default Front Passenger side window regulator/ horn beep
I had my front passenger side window regulator replaced. It's working fine after the replacement but since then my horn would now beep everytime I locked the doors using the remote.
Before the repair I would only notice the horm beep when locking the door IF i had left any one door ajjared but now it is does that short beep even with all doors closed shut.
Is there any connections between the door window replacemant and the horn beep. I was thinking that perhaps there is some kind of door lock sensor that was not place back properly during the regulator replacement.
Any tips will be appreicated.
Thanks,
Gerard
Chicago ( 2000 Disco series 11 )
Old May 25, 2011 | 05:19 PM
DarylJ's Avatar
Does your interior light shut off properly when you close the doors since your repair?
Old May 26, 2011 | 09:58 AM
Gerard's Avatar
Yes, interior lights work fine. Turn on when doors open and close when doors are shut.
Thanks for your help.
Gerard
Old May 26, 2011 | 11:09 AM
jafir's Avatar
Did you have the hood open when working on this? Maybe to disconnect the battery or something? Any change the hood switch isn't being pressed?
Old May 27, 2011 | 08:38 AM
Gerard's Avatar
Hood switch....huh....I'll give that an inspection today. Any clues to where the hoiod switch might be located.
I'm not sure if they did pop the hood up to fix the window but that is a good place to start.
Thanks,
Gerard
Old May 27, 2011 | 09:57 AM
Gerard's Avatar
Figured it out. It was the hood sensor. The sensor was bent over and not being pressed by the underside of the hood when shut.
Thanks for the tip Jafir. That was the chapest fix ever...Free!!!
Gerard
AdrenalinPlease
Feb 27, 2013 03:33 PM
Marni
Sep 15, 2011 10:03 AM
gavone1976
Jun 28, 2011 06:48 PM
Yikes!
Apr 23, 2010 01:23 PM
dcreekmore44
May 7, 2009 02:21 PM
