Front wiper switch and radio glitchy
Old Jan 25, 2016 | 03:23 PM
jamieb's Avatar
Default Front wiper switch and radio glitchy
I should just start a post titled: all the issues I have with my Rhino, and list them altogether instead of individually.
Front wiper switch on steering column - to make the wipers come on I have to rotate the switch on/off on/off a couple times to get them going. Just turning the switch a click or two does nothing. Figured it was just old and worn -- but the radio volume is the same way - to raise the volume I have to rotate the volume **** left/right left/right to raise the volume. Figured it was just worn.
But - and maybe just a coincidence, after I moved the harness by the firewall doing plug wire work, they seemed to work better a short while.
So, both worn out or did I stumble on a bad ground that controls both wipers and radio?
bcolins
Feb 2, 2014 09:40 PM
mango
May 17, 2012 04:55 PM
disco0311
Aug 2, 2008 09:54 AM
millejdq
Dec 6, 2007 12:23 PM
97DISCOIDAHO
Aug 23, 2006 04:08 AM
