Fuel smell from around the filler neck?
Old Oct 13, 2018 | 09:06 AM
longtallsally's Avatar
Default Fuel smell from around the filler neck?
I’m starting to notice the smell of fuel around the filler neck. And not just when I fill it up, but also just walking by.
There are no leaks that have seen or even damp spots from the underside. It passed CA emissions just before I bought it (I don’t live there- but is where it was purchased from) so I know the cap was good at least a year ago as that is one of their tests.
I’ve also had some issues with it shutting off the pump when filling and not even being close to full. Is the return or vent line there clogged up or something? To resolve that, I’ve just put the pump on the lowest setting so the flow isn’t so fast, but I’m starting to think they are linked.
Suggestions?
Old Oct 13, 2018 | 09:27 AM
Bulax99's Avatar
I would take a close look at the vent line for the issue. I had the same problem on a suburban I had a few years ago and with a 28gal take it was murder filling up the tank on the lowest setting at the gas nozzle. It would do the same thing your talking about. I’d start to pump gas wide open and I’d hear the fill neck fill up and then it would click off.
Old Oct 13, 2018 | 09:40 AM
It’s funny, I was literally just looking at the RAVE to find the very pic you posted. So I guess my logic is logical...
I have also heard of a recal, or TSB or the like dealing with the breather and there was a new part put in, but I wasn’t sure.
Old Oct 13, 2018 | 09:59 AM
Bulax99's Avatar
Yeah. You’re on the right track. Good luck!
Old Oct 13, 2018 | 12:49 PM
Never mind. I found it. I’m going to assume this is going to be the gasket to the fuel pump or pickup or whatever.
[IMG]https://photos.smugmug.com/Cars/Land...MG_3347-X2.jpg
EDIT: Has the process to link to pictures changed on the site? Doesn’t seem to work any longer?
Old Oct 13, 2018 | 09:54 PM
Got to the inspection plate and found the leak. Guess I get to order a new fuel pump.
EDIT: Now I can’t even upload any pics. Was just trying to help the collective. Bummer.
Old Oct 14, 2018 | 03:52 AM
JUKE179r's Avatar
Until the Mods correct it, try using the option “full site view” instead of “mobile view” and then try to upload load a picture.
Btw.. I’m on my iPhone.
Old Oct 19, 2018 | 09:21 PM
Well I’m not going to try to post pics, but I fixed the leak with a a new fuel pump. Best part? It was $135 from rockauto and was a Bosch and mirrored to a tee what I pulled. Beats the heck out of $3-500 options elsewhere.
Old Oct 20, 2018 | 05:29 PM
Bulax99's Avatar
I’m glad you were able to fix it. I would have rather changed the fuel pump in you scenario than my recent experience. No symptoms, no warning, nothing. Driving down the freeway and the pump just died on me.
Drake Anderson
May 13, 2019 08:31 PM
CollieRover
Apr 12, 2019 09:22 AM
ljdiscovery
Jan 1, 2019 08:44 PM
Geo
Sep 9, 2018 06:53 PM
Travelor
Jul 1, 2011 11:16 AM
