Fuel tank over filling
Old Mar 30, 2017 | 08:05 PM
Luckyjayb's Avatar
I wouldn't be surprised with these finicky machines. I'm just hoping it stays screwed down
Old Mar 31, 2017 | 07:14 AM
JUKE179r's Avatar
Originally Posted by Alex_M
I've been told that overfilling your tank can cause purge valve failure. Not sure if there's any truth to it, but just relaying what I've heard.
I've done this on a bunch of other cars I've had and never had problem. It's a (bad?) habit I picked up from being in the military.
Old Apr 1, 2017 | 03:12 AM
The Deputy's Avatar
Yep, when it clicks off...stop.
There is a port/tube that connects to the filler tube from the evaporation system and when you keep fueling the vehicle (after it clicks off)...you are essentially dumping fuel down that port into your evaporator system...which renders the system unless and usually throws a diagnostic code.
Brian.
Old Apr 1, 2017 | 03:32 AM
The Deputy's Avatar
Most military equipment is EPA exempt...so, emission systems are deleted (nonexistent). You may run into some emission systems on the stock light duty vehicles running around base (chevy, fords, etc), but militiary grade/battle ready vehicles would be exempt.
Especially, the diesel engines nowadays...couldn't imagine them holding up a battle...just so the operator of the vehicle could do a regen on the emission/DPF system...lol.
Thank you, for your service. Granted, if you were in charge of filling up the light duty vehicles...the mechanics in the motor pool probably hated you... they were probably like...why in the hell are all of these damn check engine lights always on...lol.
Brian.
Old Apr 2, 2017 | 04:37 PM
OffroadFrance's Avatar
It is often 'blowback' from overfilling that causes the fuel to escape via the breather but in truth the breather should not overflow externally. Don't overfill the fuel tank as the truck won't go any extra appreciable distance in any event but it wastes the fuel spilling onto the road when you drive away.
Sooners
Oct 25, 2018 12:50 PM
mpothen
Mar 23, 2016 08:42 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
camaroz1985
May 5, 2010 05:35 PM
nwcarter3
Sep 13, 2006 10:35 PM
