Fuel Trim
Old Nov 10, 2018 | 08:07 PM
redrover75's Avatar
Default Fuel Trim
So, I have been chasing a p1415 and p1412. I am unable to find a vacuum leak at this point, replaced the intake valve, checked all the hoses, and connections.
Now, I have a p1412, p1415, p0101, p0175, p0172.
Cleared those codes, and now the p0175 p0172 are back. I installed the fuel trim gauges on the Torque app. I have what appears to be normal figures on bank 1. But bank 2 is flat lined, no measurements at all.
It appears to run fine, maybe a bit unsmooth, but not the way I would expect if I were only running on 1 bank.
Any idea on where to start?
Thanks,
Old Nov 10, 2018 | 08:31 PM
Extinct's Avatar
Sounds like a bad 02 on bank 2. Swap the 02s left to right and see if it follows them. If it does, bad sensor. If it doesn't, likely a circuit issue. Report back here for next steps.
Old Nov 10, 2018 | 10:33 PM
Twix's Avatar
If 1 O2 goes bad, the engine will try to trim using the other bank's sensor. Like extinct said, swap from side to side and see if the problem swaps.
It could also be a bad intake manifold gasket, bad injectors, bad plugs, bad wires etc..
I had a similar issue awhile back, turned out my MAF was just reading a bit off. left bank didn't seem to mind, but the right bank was throwing codes.
Old Nov 13, 2018 | 08:17 PM
redrover75's Avatar
Default Update
So I cleaned the maf and cleared codes. Did not mess w O2 sensors yet. I am down to P0172, P0175, p0101.
when I clear the codes these are the only ones that persist. Looking at the fuel trim gauge, bank 2 does not often read any value. The O2 sensors appear to read values, even if they do not read matching values.
my thinking is to replace both O2 sensors, I bet mine are original. Any other thoughts are appreciates.
Old Nov 14, 2018 | 05:30 PM
Extinct's Avatar
Your first screenshot seems to indicate 02's cycling, the remaining ones are a little questionable on bank 2 because I can't see them cycling. You want to see the 02's cycling on a semi-regular basis. If one is dramatically slower than the other, or does not cycle at all, you have a bad 02. If they cycle, there is nothing wrong with them. That is a general rule, in detail the ECU occasionally throws a rich or lean condition in to the mix just to make sure they are working right, and of course it will go to full lean if you are decelerating for an extended period of time with zero throttle opening. Best to do the test at idle, engine warm.
But based on what you have here, I think our original suspicion regarding bank 2 warrants swapping left to right.
Old Nov 15, 2018 | 08:23 AM
redrover75's Avatar
That is very helpful, thank you. I ll swap and see what happens.
Old Nov 18, 2018 | 10:31 AM
redrover75's Avatar
Default Wiring
It turns out the passenger side o2 sensor has beat up wiring connection. I think I need to replace it and might as well do both, right?
only worth buying bosch?
Old Nov 18, 2018 | 02:26 PM
mollusc's Avatar
Don't get Bosch O2 sensors. They have a high failure rate out of the box. Walker ones seem to be much more reliable.
RicketyTick
Jul 2, 2014 11:46 PM
Soul97
Feb 16, 2014 07:20 AM
maing74
Apr 27, 2012 07:45 AM
jycsalas
Dec 4, 2010 11:16 AM
jack112286
Dec 18, 2009 06:34 PM
