Fuel Vapor Codes
Old Feb 29, 2024 | 07:13 AM
alw85's Avatar
Default Fuel Vapor Codes
Climbed under my Disco yesterday to verify some things before buying parts to alleviate some codes. I have a 2000 Discovery and it doesn't have the leak detection pump at the canister like to 03-04's do but I'm getting the P1451 code for it. Also, I've noticed once the Disco gets about half a tank of gas it doesn't want to take anymore; could this code be for a plugged/bad charcoal canister not allowing fuel vapors back up to the purge solenoid? I did replace the purge solenoid yesterday because it wasn't operating correctly.
Old Feb 29, 2024 | 09:22 AM
H20nSnow's Avatar
Our trucks have badly designed fill necks. For me it depends on where I'm filling up. Some pumps are fine, some - like my local station - the spout needs to be pulled half way out of the truck to fill well, and even then I need to slow the fill rate, then it fills full.
Old Feb 29, 2024 | 12:36 PM
Harvlr's Avatar
This may not be your refuelling issue, but this was mine.
https://landroverforums.com/forum/di...ittent-111773/
Old Mar 16, 2024 | 05:33 PM
alw85's Avatar
I replaced the vapor canister today and started the truck up and it didn't lag like before; I'm hoping it solves the issues but won't know until Friday when I go to fill up. The old canister was a bit heavier then the new one and the filter media to fresh air inlet looked plugged.
alw85
Feb 25, 2024 02:35 PM
boston4
Dec 16, 2019 08:11 PM
chubbs878
Aug 16, 2015 11:48 PM
kman35ca
Nov 3, 2011 11:14 AM
bearcatfans
Oct 15, 2009 09:12 AM
